Door panel repair tips, tricks, voodoo?
Old Jul 3, 2017 | 10:41 AM
Eastflorida's Avatar
Got the door panel off thanks to Joe.
What trick or tips do you guys have to fix the door panel where the clips have pulled through?
Old Jul 3, 2017 | 12:41 PM
No magic solution, just brute force. If the damage is only local, you can try a resin and fiberglass cloth patch. Otherwise, fabricate new door cards and transfer the upholstery.
Old Jul 3, 2017 | 01:08 PM
Or if your not into purity a few of these well placed work well also.
Old Jul 3, 2017 | 02:05 PM
I'm sorry, but I've spent the better part of the last year undoing half-fast repairs on my 67 Delta. Previous owners have welded hex nuts to the sides of the lower control arms as steering stops due to worn out suspension bushings and incorrect wheel offset, hacked and destroyed the HVAC box to fit an incorrect heater core, pulled fuses to bypass crappy wiring, lost the rear brake self adjuster mechanisms for who know what reason, routed a nearly flat exhaust pipe to run duals with the wrong LH manifold, forced an incorrect Saginaw center link into Thompson idler and pitman arms and stripped the threads on the brand new center link as a result, etc, etc.
I've had it up to HERE with half-fast repairs.
Old Jul 3, 2017 | 03:47 PM
mrolds69's Avatar
If they are not bad, sometimes you can soak the area w/ CA...like superglue from a hobby shop. It works better on like Ford type chipboard panels. Those are too far gone for that.
Old Jul 3, 2017 | 04:10 PM
A few screws does not compare to your Ethiopian engineered modifications.
Old Jul 3, 2017 | 04:32 PM
But they DO punch holes in the factory upholstery...
Cpriester123
Aug 23, 2016 06:57 PM
elbole
Mar 8, 2014 05:55 AM
wikkonado
Dec 11, 2013 03:08 PM
RAMBOW
Jan 12, 2012 08:25 PM
Aceshigh
May 26, 2011 03:32 PM
