Dash vent convertible
Hello Gents,
seems that my upper kick panel cable is broken/disconnect.
Is it possible to change the cable or have the dash board to been taken out ?
Thanks, Marc
Thanks, Marc
You will need to reach up under the dash to disconnect that end of the cable from the vent, but once you do that you can remove the kick panel and swap the cable. Removing the glove box should help.
