console fittings
Old Mar 17, 2011 | 10:50 PM
knighthawk's Avatar
From: from Wisc, then Texas, then Kansas, now back to Texas,
console fittings
'69 Cutlass S shifter console....I have 2 white plastic ''tee'' shaped fittings about an inch long. I remember the heads fit in square opening, also there's 2 screws about an inch long , but can't figure out where ? Where do they go ? ...thanks
Old Mar 18, 2011 | 09:37 AM
knighthawk's Avatar
that's strange !that nobody yet has seen these, maybe this post will bring it back to top .....
Old Mar 18, 2011 | 12:53 PM
knighthawk's Avatar
OK, now I'm really confused, I've had the console apart several times, repairing it and making it fit, nowhere did I see where the plastic things go ! SO........ where did they come from ?????????/
Old Mar 18, 2011 | 01:35 PM
A photo of what you're talking about might be helpful to the rest of us.
Old Mar 18, 2011 | 02:00 PM
knighthawk's Avatar
my thoughts excactly! just got it....
Old Mar 18, 2011 | 09:22 PM
2blu442's Avatar
Do they have a threaded hole in the round part? I'll look this weekend to see if I can find anything like that. John
Old Mar 19, 2011 | 07:18 AM
knighthawk's Avatar
yes, and I think there was a screw comming thru from something into this end of the plastic. I got this picture in my head of the square end fitting a square receessed hole.......
Old Mar 26, 2011 | 05:42 PM
knighthawk's Avatar
nothing yet ?
Old Mar 26, 2011 | 05:52 PM
69442C's Avatar
I have a 69 442 automatic console that is currently apart in the basement and it doesn't have parts that look like the parts you show in the picture. Although I did find a quarter and a dime like that, along with a lot more coins when I removed the console!
Any chance these were bushings that fit between the console and a mounting bracket in the car?
Old Mar 26, 2011 | 06:13 PM
2blu442's Avatar
I agree with 69442C, I looked over a console and didn't see a place for those. Now that I think about it... I believe there's a couple pieces like that inside a non-sport steering wheel, under the horn button. Could they be from there? John
Old Mar 26, 2011 | 07:54 PM
W70442's Avatar
They look like license plate nuts to me.
Old Mar 27, 2011 | 08:54 AM
69442C's Avatar
2blu hit the nail on the head. Those plastic pieces fit into the horn plate for the standard steering wheel. I've enclosed a photo showing where it goes and I removed the other side to show the bottom of it. A screw goes into these from the back of the steering wheel.
Old Mar 27, 2011 | 10:33 AM
knighthawk's Avatar
WOW!!! looks like that's it ! I must have put the horn button on with out them ! thank you guys ! I mean it !..... thanks again !!!!
Old Mar 27, 2011 | 11:03 AM
69442C's Avatar
There are springs under that horn plate too that go around the round portion of the plastic parts. So if you put the steering wheel together, you may have forgotten about those too. Check in the console storage bin.
Old Mar 27, 2011 | 11:38 AM
knighthawk's Avatar
OK ! Here's the scoop ! they ARE horn button thingys, BUT, mine are in there. That means they were in the used console compartment when I got it . So.....now I have 2 extra plastic fittings for the horn button....if anyone needs some let me know..... thanks again guys !
mcutlass1969
Dec 20, 2011 11:49 AM
crazy'boutOlds
Sep 11, 2011 01:00 AM
devmar07
May 14, 2010 09:23 AM
alsmith
Mar 9, 2010 09:30 PM
cornwallis
Sep 21, 2009 08:44 AM
