Climate Control
Old Sep 1, 2019 | 05:24 AM
Phoenix8990's Avatar
Climate Control
I have a 69 Cutlas and getting the heater/AC fan switch is difficult. In 70 they went to a different type switch. I'm wondering if they are interchangeable? Or can you switch the entire assembly? Do they continue using vacuum lines for dampers? The newer switch which goes up and down vs. turning is available. Might have to modify the front plate a bit. basically i need a solution for a bad fan speed switch.
thanks,
Steve
Old Dec 4, 2020 | 07:18 AM
jacksippel's Avatar
Jacks64conv
did you find a climate control assembly for your car?
Old Dec 4, 2020 | 07:59 AM
thanks,
Steve
68-69 is a rotary switch. 70-72 is **** that moves up and down. They only "interchange" if you change the whole control plate.
Old Dec 4, 2020 | 08:04 AM
I took it apart and discovered I was not the 1st person to do so and it was not reassembled correctly. It now works fine. Joe, just wondering if the 70 control uses vacuum lines as well. Would they be interchangable?
thanks,
Steve
Old Dec 4, 2020 | 08:07 AM
thanks,
Steve
The A/C cars use the same vacuum controls. The heater-only cars use cables. The box under the dash is the same from 1968-72.
Old Dec 4, 2020 | 08:10 AM
Quick question. I have a feeling I need to replace a heater core, is it difficult in an AC car?
Steve
Old Dec 4, 2020 | 08:18 AM
Steve
It's difficult on any 68-72 A-body. You have to at least remove the inner fender to access the fasteners that hold the HVAC box to the firewall. If there's any rust, the odds are high that at least one of the clip nuts that hold the inner fender to the outer will spin when the bolt seizes, which will force you to remove the whole fender.
Old Dec 4, 2020 | 08:24 AM
Oh Boy, does not sound like a fun job. So it would be removed from the engine compartment side? Thanks for the response
Old Dec 4, 2020 | 08:27 AM
The heater core is in the box under the dash. It comes out from the passenger compartment. It's fastened to the firewall with fasteners (bolts and nuts on studs) that must be accessed from the engine side of the firewall.
Old Dec 4, 2020 | 08:28 AM
I'll add that when you do that, put in a new blower motor at the same time. That's a MIGHTASWELL that's well worth it.
Old Dec 4, 2020 | 09:05 AM
Thanks for the quick answers, it gives me something to think about while my broken leg recovers.
Steve
Old Dec 4, 2020 | 03:17 PM
jacksippel's Avatar
Jacks64conv
I do have the one for a 68-69
BSiegPaint
Jul 18, 2018 01:05 PM
Arthur T. Berry
May 2, 2014 02:04 PM
jo75olds
Mar 31, 2011 07:08 AM
1973olds98
Oct 25, 2010 05:14 AM
jcabbott13
Jun 25, 2009 08:20 AM
