Back seat removal
Old July 18th, 2014, 02:22 PM
Snolab's Avatar
Back seat removal
Guys I'm apparently old and weak. How in the flying *%#+##!! Do I get the back seat "back" section out of my 69 442? The bottom edge has tabs and I got those off but when I try to lift up to get the back portion out I get no movement? Help!!!
Snolab is offline
Old July 18th, 2014, 02:34 PM
If you have disengaged the lower front portion on both sides from the clips then all you need to do is lift and pull it forward. The upper part of the seat has two screws on the lower part that need to be removed then lift it to clear the tabs on top.
oldcutlass is offline
Beer Connoisseur
70cutty's Avatar
There is 2 bolts on the bottom that have to be removed, push in and up, that's how I got mine out.
70cutty is offline
Old July 18th, 2014, 03:37 PM
jaunty75's Avatar
To clarify, this is how you get the seat back out. As oldcutlass says above, getting the seat bottom out requires simply pushing back on it until the clips disengage and the pulling up and out. There are no screws to remove in getting the seat bottom out.
jaunty75 is offline
Old July 18th, 2014, 03:48 PM
Beer Connoisseur
70cutty's Avatar
Jaunty please read op's question, he didn't ask about the bottom.
70cutty is offline
Old July 18th, 2014, 04:31 PM
jaunty75's Avatar
You're right.
If he has the bottom edge tabs off, all he should have to do is lift.
jaunty75 is offline
Old July 19th, 2014, 09:58 AM
scott_442's Avatar
Those can be a bear sometimes...I've actually had to remove the front seats and sit on the floor with my back against the seat bottom and push backwards to get the bottom to move enough to where it would lift up and out of the tracks! But I"m also old and weak!
scott_442 is offline
Old July 21st, 2014, 01:42 AM
Yellowstatue's Avatar
I have found a seat in possibly a '68 Cutlass that had one Philips screw installed from the trunk side, but only one.
Yellowstatue is offline
Old July 21st, 2014, 03:37 AM
brown7373's Avatar
The seat back "hangs" on 2 tabs at the top behind the seat back, so you lift up to lift it off those 2 tabs. Mine is a bitch to get off. I'm not sure if the tabs are slightly bent, but I have to lift and kind of wiggle the top to get it to lift off the tabs.
brown7373 is offline
SIRJR
May 16th, 2012 04:18 AM
Tony72Cutlass'S'
January 15th, 2012 05:50 PM
Chumley
July 6th, 2011 10:18 PM
68Verts
March 20th, 2011 06:48 PM
ctrain22
August 15th, 2010 08:46 PM
Quick Reply: Back seat removal
