Back seat removal
Old Jul 18, 2014 | 02:22 PM
Snolab's Avatar
Back seat removal
Guys I'm apparently old and weak. How in the flying *%#+##!! Do I get the back seat "back" section out of my 69 442? The bottom edge has tabs and I got those off but when I try to lift up to get the back portion out I get no movement? Help!!!
Old Jul 18, 2014 | 02:34 PM
If you have disengaged the lower front portion on both sides from the clips then all you need to do is lift and pull it forward. The upper part of the seat has two screws on the lower part that need to be removed then lift it to clear the tabs on top.
70cutty's Avatar
Beer Connoisseur
There is 2 bolts on the bottom that have to be removed, push in and up, that's how I got mine out.
Old Jul 18, 2014 | 03:37 PM
jaunty75's Avatar
To clarify, this is how you get the seat back out. As oldcutlass says above, getting the seat bottom out requires simply pushing back on it until the clips disengage and the pulling up and out. There are no screws to remove in getting the seat bottom out.
Old Jul 18, 2014 | 03:48 PM
70cutty's Avatar
Beer Connoisseur
Jaunty please read op's question, he didn't ask about the bottom.
Old Jul 18, 2014 | 04:31 PM
jaunty75's Avatar
You're right.
If he has the bottom edge tabs off, all he should have to do is lift.
Old Jul 19, 2014 | 09:58 AM
scott_442's Avatar
Those can be a bear sometimes...I've actually had to remove the front seats and sit on the floor with my back against the seat bottom and push backwards to get the bottom to move enough to where it would lift up and out of the tracks! But I"m also old and weak!
Old Jul 21, 2014 | 01:42 AM
Yellowstatue's Avatar
I have found a seat in possibly a '68 Cutlass that had one Philips screw installed from the trunk side, but only one.
Old Jul 21, 2014 | 03:37 AM
brown7373's Avatar
The seat back "hangs" on 2 tabs at the top behind the seat back, so you lift up to lift it off those 2 tabs. Mine is a bitch to get off. I'm not sure if the tabs are slightly bent, but I have to lift and kind of wiggle the top to get it to lift off the tabs.
SIRJR
May 16, 2012 04:18 AM
Tony72Cutlass'S'
Jan 15, 2012 05:50 PM
Chumley
Jul 6, 2011 10:18 PM
68Verts
Mar 20, 2011 06:48 PM
ctrain22
Aug 15, 2010 08:46 PM
