Adding gauges - need advice on routing
Old Jul 21, 2017 | 04:03 PM
Eastflorida's Avatar
OK, I'm ready to install Oil, Water and Volt gauges. I'm scared to cut through the firewall so I'm looking for suggestions and pics where you cut and how you routed your oil, water and voltage...
Thanks sooo much!
Old Jul 21, 2017 | 05:14 PM
70sgeek's Avatar
'72 Cutlass ragtop
I'm using the same gauge enclosure as you in my '72.
I drilled a hole in the floorboard just right of the transmission hump, behind the carpet, this way it's hidden. Hole doesn't have to be large, just enough to allow free passage of your lines. Fit a grommet into the hole first to shield your lines from the bare metal hole edge.
you can also apply some sealant around the lines once routed, to weatherproof the site.
Old Jul 21, 2017 | 05:20 PM
Any pics by chance????
Old Jul 21, 2017 | 05:31 PM
70sgeek's Avatar
'72 Cutlass ragtop
nothing immediately handy but I believe the hole I drilled was somewhere around 1/4" or so in diameter - it's best to start small and drill larger only as you need to.
I passed my lines up through the firewall wiring and intake looms to their end locations so things stayed clean under the hood.
Old Jul 21, 2017 | 07:06 PM
I've always just squeezed the wires / tubes through existing grommets, werever they would fit.
No drilling, no holes, no mess.
Old Jul 21, 2017 | 07:11 PM
I can't find anything which is why I'm asking for pics!!! LOL!!!
Old Jul 21, 2017 | 07:28 PM
Usually the A/C vacuum lines and wires come through about a 1" hole, and there's plenty of extra room there for additional lines.
Old Jul 21, 2017 | 09:24 PM
Yeah, from what I remember there is a large hole near the steering column. I didn't need to make a hole on either my 70 Supreme or the 71 convertible, just routed the sending unit and pressure tubing through that existing hole.
Old Jul 22, 2017 | 12:34 AM
I ran a mechanical temp gauge through the firewall under the column, and I mean I pushed the sending unit through, so there's room for electric wires.
Old Jul 22, 2017 | 10:28 PM
Thanks for the help guys, got it done...
Joe68hurst
Hurst/Olds
Dec 26, 2016 12:51 PM
Alex72cutty
May 30, 2014 03:20 PM
terrapin
Aug 7, 2012 06:25 PM
citcapp
Dec 14, 2009 11:10 AM
perro
Sep 4, 2007 11:52 PM
