75 H/O Sail Panels & the Courtesy Lights
Old Aug 19, 2024 | 04:22 AM
radiofellow50's Avatar
On my newly acquired 75 Hurst, the sail panels are there but the vertical courtesy lights don't cover the entire cut out on those panels. In other words, there's about a 3/4" gap at the bottom of the cut out for the light, that is not covered. I'm assuming that the light is somehow mounted too high on the panel. How do these come off? I don't want to break the plastic?
Old Aug 20, 2024 | 12:58 PM
Tuffnut's Avatar
I have some courtesy lights and sail panels off 75 supreme parts car I can take a couple of pics for you in a few days.
Old Aug 20, 2024 | 01:04 PM
Super, thanks
Old Aug 22, 2024 | 03:02 PM
Tuffnut's Avatar
Here are some pictures from my 75 supreme spare parts.
Remove the plastic lens, screws that hold the light assembly to the body. Not the plastic sail panel.
Jeff
Old Aug 22, 2024 | 06:49 PM
Appears those light are about the same size as the one I have except for the fact that your panels don't have that 1" space showing at the bottom of the lights in my pics?
I doubt the sail panels changed shape so maybe someone but out the sail panel for some kind of different light. Hard to tell as the car is 50 years old!
Bob
Old Aug 22, 2024 | 08:14 PM
FStanley's Avatar
1. I seriously doubt the lens are different size length for a 75 HO panel. I suspect the panel cutout is wrong for some reason..
2. Also both of you should measure the length of your lenses and compare..
Jeff
Old Aug 23, 2024 | 02:16 AM
I'lll get a measurement. It seems those sail panels are unobtainable but wonder what they are made of or do you know someone that is making them?
Old May 24, 2025 | 08:15 PM
So, turns out on my H/O sail panels, it appears they have slipped down and that created the gap at the bottom of the courtesy light. But, the things are VERY brittle and I'm going to try my hand at making a reproduction out of either ABS plastic or polyethylene sheets. Not quite sure how yet.
Old Jul 12, 2025 | 05:33 AM
CutlassMarc's Avatar
Have it 3d printed.
dglyle
Sep 8, 2017 08:34 PM
deaddds
Hurst/Olds
Mar 16, 2017 01:19 PM
rml442
Feb 6, 2017 09:00 AM
Hurtin hurst
Feb 2, 2017 08:12 AM
