71 442/Cutlass AC Duct
Hi All! I am new to the forum but I had a question. Is the duct work under the dash the same for an AC car & Heater only car? Is the control panel the same except for the face plate?
Were these actually separate molded parts, or did Olds simply cut the A/C duct to clear the 8 track player (similar to cutting the 70-72 consoles for the MT or dual gate)?
If you had a factory installed 8-track there were 2 seperate pieces and part numbers for the lower valance. If it was dealer installed there was a template included with the 8-track unit for cutting it.
Ahhh, I love the smell of part numbers in the morning.
The valance cutout template is #406656.
I'll be hacking mine in half next week after I install the 8-track and maybe I can make one.
I'm a carpenter and if I can't cut that straight and fit it right without a template shame on me.
I was planning on using a chain saw to do the deed.
The template copies will be available to the general public for a nominal printing fee plus $73.47 shipping and handling.
Cross cut
Bringing back an old thread as a result of a post by 1971four4two's for sale add....
I have a set of split ducts in my 1971 but removed the 8-Track. Obviously I could still use the split duct but it sounds like they may be something that a 8-Track owner may prefer over cutting a one piece. What does the single duct look like? Are they easier to obtain than the two piece?
dsolomon good luck selling your 8track ducts I have seen the 1 piece duct for $125 If yours are really nice IMO your 8track ones should be worth that or more! Cheers!
post some pictures!
post some pictures!
Bernhard
April 27th, 2013 10:54 PM
