68 sport wheel question
Old May 26, 2009 | 01:16 PM
68Tom's Avatar
OK, I put the new hub on my steering column for the sport wheel, using the large nut that is on the spindle in the center of the column. Is there anything else to secure this, or is that all?
Second, are the screws that come with the wheel/kit the only thing that connects the wheel to the hub? In other words, this seems slightly odd, as I now don't see the need for a steering wheel removal tool--nothing really is locked down or in. Is this correct, or did I remove my original style wheel and misplace some long bolts?
It's been awhile since it was removed, hence why I'm asking.
Old May 27, 2009 | 10:30 AM
68Tom's Avatar
So you mean to tell me that no one here has installed a sport wheel on a 68-69? Heck, I'm guessing even the 70 wheel is similar.
Old May 27, 2009 | 04:26 PM
68conv455's Avatar
I think you are correct here. Once the hub is connected with the large nut that threads onto the column shaft, the wheel connects to the hub with three screws (If there are three than I think you are good to go). The puller is normally used to pull the wheel off the steering shaft. In this case, it is the hub only that may get stuck.
P.S. It has been a while for me too. I'm drawing from memory.
Old May 27, 2009 | 06:43 PM
2blu442's Avatar
Yes, I agree with you guys. The hub needs to be removed with a puller, but the sport wheel attaches to the hub with I believe 6 screws, then the horn contact attaches with 3 screws. I've got some photos of a 1970 sport wheel which attaches in a similar manner. If you have any questions about the horn contact let me know. John
Old May 27, 2009 | 09:34 PM
When I was going to college in the Boston area, I had my 67 Cutlass beater stolen, forcing me to drive my 68 442. With practice, I was able to remove the sport steering wheel in under 90 seconds by undoing the horn ring and six phillips screws and would take the wheel with me to my dorm room. This definitely stopped the theft attempts.
Old May 28, 2009 | 02:16 AM
Yellowstatue's Avatar
Smile Tighty
The shaft is tapered, that's why you need a puller to get it off...
Old May 28, 2009 | 06:56 AM
68Tom's Avatar
Ah, ok. Thanks guys. That makes sense. The hub is what will eventually need the puller.
pfergy600
Jun 11, 2015 06:47 PM
Keegan
Feb 19, 2014 07:23 PM
StickW31
Jun 3, 2011 08:24 AM
orange442
May 14, 2006 03:03 PM
