68 lower dash bezel removal??
Old October 15th, 2009, 06:39 PM
ctrain22's Avatar
What is the easiest and best way to remove/replace the lower dash bezel on a 68? I am talking about the long black w/chrome trim plastic piece that houses the switches. I need to access the wiring behind it to repair some cut wires and think that's the best way. Or is it??
ctrain22 is offline
Old October 15th, 2009, 07:06 PM
2blu442's Avatar
Hi Charlie
I've always removed the complete dash assembly, then separated the pad from the long plastic lower section. I'm not sure you can remove the lower plastic and leave the pad on. I've got a dashboard in the garage, If you don't get a for sure answer by tomorrow evening I'll try to take some pictures of how the pad is attached to the long plastic piece. John
2blu442 is offline
Old October 16th, 2009, 09:10 AM
68Tom's Avatar
Nope, they're connected by screws. You'd have to remove screws into the pad first, which I think would be extremely difficult with it connected to the dash. I could be wrong, but basically, it's easiest if you remove the pad and the bezel. Thanks to the speedo cable, it doesn't pull out that far. So, you might want to remove that as well.
Don't forget, there's a screw, I believe, up in between the speedo pod and the clock/tach pod holding the pad and bezel to the dash. Check the assembly manual if you can't find it. It's a real joy getting to that one.
68Tom is offline
Old October 16th, 2009, 09:45 AM
What he said. Either get used to the idea of being upside down with your head under the dash and your legs draped over the seatback, or remove the front seat.
joe_padavano is offline
mrnursedude
November 12th, 2019 03:27 AM
oldspackrat
February 14th, 2013 09:04 PM
Rocketbrian
January 13th, 2012 10:10 AM
Bryan59EC
June 3rd, 2010 10:36 AM
Quick Reply: 68 lower dash bezel removal??
