68/69 console
Old Jan 14, 2019 | 07:41 PM
servexcell's Avatar
68/69 console
Is there any modification to do to the shifter console when replacing 2 speed jetaway to Turbo 400 transmission?
I have a new kit with new lens and cable. Does the chrome plate hjave to be modified?
Bruce
Old Jan 15, 2019 | 06:37 AM
Bruce
The only changes are the curved gate in the shifter (so you have detents for all three forward gears), the gear indicator lens, the cable, and the bracket on the trans pan that holds the lower end of the cable. Everything else is the same.
Old Jan 15, 2019 | 08:00 AM
servexcell's Avatar
Hi Joe
does the chrome base that fits over the shifter have to be modified.
thanks
Old Jan 15, 2019 | 08:06 AM
Hi Joe
thanks
From above:
Old Jan 15, 2019 | 01:23 PM
69455's Avatar
I had to modify the top chrome plate as well as the curved metal gate to allow for extra travel on mine.
Old Jan 15, 2019 | 01:33 PM
Then you did something wrong.
There is only one P/N for that panel on the 67-69 AT consoles - 396000 (without the applique). This is for both two speed and three speed applications. I'm guessing that your mods to the curved gate were not the same as OEM, thus the problem with excessive travel.
Chuxter
Jun 2, 2016 01:12 PM
4speed455
Nov 17, 2015 02:55 PM
68442
Dec 31, 2014 05:48 PM
Oldsguyhill
Mar 20, 2014 08:30 PM
raider973
Apr 14, 2013 02:59 PM
