67C/S headliner
Old Nov 25, 2017 | 09:02 AM
brianbeez67's Avatar
67C/S headliner
Just put my old sun visors in the car, look Terrible.
Thinking about spray painting the (original black). Does anyone know what type/style spray paint would look best ?
Thanks Brian
Old Nov 25, 2017 | 10:06 AM
RandyS's Avatar
SEM Landau Black. Works wonderful!! Buy online or at your local auto paint store.
Old Nov 27, 2017 | 09:59 PM
RAMBOW's Avatar
Ben
Why not just replace the headliner with one the color you want?
A new one is barely more than the cost of the vinyl cleaner & the paint/dye
Old Dec 14, 2017 | 07:21 PM
cjsdad's Avatar
Use a vinyl dye. Paint will eventually start flaking off, the dye will not. Your local upholstery shop should have the color you want. If not, Amazon and ebay do.
Old Dec 15, 2017 | 02:00 AM
Your local auto parts store should also carry vinyl dye.
Old Dec 21, 2017 | 02:42 PM
RAMBOW's Avatar
Ben
FYI- Vinyl "dye" is not a dye. It does not penetrate the vinyl in anyway.
It is a paint that has more flexible and adhesion properties than average paint does.
most headliners can be restored to a nice look using:
1. a steamer to loosen the dirt & grease
2. simple green & a scrub brush to remove the dirt & grease.
Steam it, then scrub it, then steam it again and wipe it clean.
This does assume the stiches are not dry rotted and come apart when you start putting pressure on it from cleaning... which happens a lot with 50 year old stitches.
I've brought white headliners back to life with the above steps.
ztim
Jul 10, 2009 05:28 PM
rickbmac
Oct 9, 2008 08:02 PM
Topless72
May 21, 2008 07:39 PM
tarps3
Feb 16, 2007 03:04 PM
<mx3racer>
Dec 30, 2005 04:21 PM
