67 C/S window channel
Old Apr 10, 2021 | 04:39 PM
brianbeez67's Avatar
The door window is loose/not in the channel. The channel rubber is shot. In this pick from the body manual says its a “Filler”, Has anyone replaced this piece . If so what did you use?
Old Apr 10, 2021 | 04:58 PM
The stuff you want is called "glass setting tape". It comes in different thicknesses. I believe 1/16" is most common.
Old Apr 14, 2021 | 04:15 AM
Window. Channel
Thanks Joe I’ll give it a try
edzolz
May 28, 2015 04:22 AM
therobski
Apr 21, 2015 01:24 PM
Warhead
Sep 26, 2010 07:24 PM
Four Four Tony
Apr 12, 2010 08:26 AM
fizzy55
Sep 30, 2009 09:18 PM
