442 Power Driver's Seat Question?
Old Apr 9, 2009 | 02:02 PM
69442's Avatar
Does anyone know where I can buy driver's side power bucket seat parts for a '68-'72 442? Such as: the electic motors & cables. Thank you in advance!
Old Apr 9, 2009 | 02:19 PM
68Tom's Avatar
Yikes. Not to discourage you, but good luck with that. I'm guessing you're going to have to have your seat motor rebuilt. From what I've read, it's not too difficult a job provided you find the right person.
As far as cables are concerned, place a wanted ad on 442.com. Also, you can try a few places I've had luck with such as Central Grade Auto (208-743-9505) and All American Classics. http://www.allamericanclassics.com/
I'm guessing the GM A-bodies used similar parts, cables and motors from 68-72. Someone might be able to chime in here on that, but you might find what you're looking for from some of the Chevelle parts houses.
Old Apr 9, 2009 | 04:20 PM
The 67-72 A-body seat tracks are the same.
Old Apr 10, 2009 | 03:08 AM
Yellowstatue's Avatar
Smile Electra Glide
The motor assembly from a bench seat car will work if it is a four-way...If your cable casings are intact then you could use the inner drives from the longer bench seat donor, shortened to length..
Old Apr 10, 2009 | 05:28 AM
Yes. Most people do not realize this.
Old Apr 10, 2009 | 04:16 PM
68conv455's Avatar
I'm re-covering the front buckets for my 68 cutlass S. The drivers seat is power and I've taken the power assembly off to do the work. I've looked on E-bay because I'm curious about the value of the power seat assembly. I've seen at least two different sellers in the past few weeks selling the assembly. (It bolts in where the seat tracks normally go). Haven't seen them as catalogue items new. The assembly should look like this.
Old Apr 11, 2009 | 02:45 PM
Bluevista's Avatar
Registered
USA Parts Supply has the cables and rebuilt motors, some other parts.
http://www.usapartssupply.com/default.htm
oldspackrat
Sep 29, 2014 01:35 PM
cdaolds
Oct 29, 2013 04:21 PM
f-85
Jun 11, 2012 12:30 PM
jensenracing77
Apr 5, 2011 08:44 PM
KZ442
Apr 10, 2009 03:16 AM
