3 point rear belts in ´70 Cutlass Conv.
Hello everyone.
Question: Has anyone done this? 3 point rear seat belts in a 1970 Cutlass Convertible?
It has the 4 attachment point in the floor for lap belts.
Søren
Søren
Rear seat shoulder belts were a rare factory option. The Fisher Body Manual shows where the attachment points are. Note that the factory shoulder belts were the "four point" style, just like the front belts. The shoulder belts used separate buckles from the lap belts, though the inboard belt ends were anchored at the same bolt on the floor.
Note to myself: Has to put Fisher body Manuel on the wishlist.
Thanks Joe. I could have been more clear. It doesn't have to be original belts, aftermarket or used out of a newer car would be just as good. Roll up belts even better.
Søren
Søren
I understand, but I still recommend the factory belts since the attach points are structurally designed for the load application at these points. It makes no sense to install belts if the anchor points can't survive the load.
I'm watching here, too. Was made to look into this by my wife - two child seats need to go on the rear bench this summer.
Now here in Germany most child seats are of the Isofix type:
http://en.wikipedia.org/wiki/Isofix
While those seats are primarily fixed between seat and backrest, they require a 3 point belt for proper fixation.
Moved the child seat anchor stuff to another thread to keep this clean:
https://classicoldsmobile.com/forums...t-anchors.html
I have purchased the following seatbelts for my 72 cutlass rehab project. It comes with
mounting hardware that anchors to the body. My kids have graduated from child seats.
http://ezon.impactfulmedia.com/e-z-o...ersal-harness/
Soeren, did you see this thread?
There's some pictures in posts 17 and on:
https://classicoldsmobile.com/forums...eat-belts.html
I was dealing with the same issue, my 69 body manual does not show 3 point anchor bolts in the rear for a convertible. It maybe different for 1970, but I don't believe!
We decided to go with a seat suitable for 2 point belts. AFter she is to heavy for group 1 we will let her sit in the front with a child seat and three point belt, which is also recomended by law - at least in Germany!
Greetings
Andi
Greetings
Andi
Aceshigh
Jun 21, 2016 05:28 AM
Klayfish
Jun 9, 2011 10:39 AM
