1976 cutlass s interior
Old Jan 28, 2021 | 08:00 PM
Dan Gleebitz's Avatar
Can I fix some of the interior trim or does anyone know someone that can restore my trim? Thanks
Old Jan 29, 2021 | 06:03 AM
Unfortunately, that's the self-destructing plastic that GM used in the late 70s. No one reproduces these parts. Short of patching it with fiberglass or other molding compound, finding good used is your only other option. Sorry.
Old Jan 29, 2021 | 07:28 AM
crimsoncolby's Avatar
The sail panel trims are especially difficult to find in good condition. To help expand your search, besides the Cutlass they are shared with the '74 Chevelle, '74 Century (large window) and '74 Lemans (large window).
I do have the trim piece that goes above the rear window if interested. PM me and we can discuss.
Old Jan 29, 2021 | 11:13 AM
Bfg's Avatar
Bfg
The black ones held up the best, so if you can find those go for it. Something to do with the ultra-violet rays. You would think the black ones would suffer the most, but is just the opposite.
Old Jan 29, 2021 | 11:19 AM
Yep...and white fared the worst. Impossible to find those.
Old Jan 30, 2021 | 01:10 AM
Grayghost's Avatar
I don't know if this is an option for you, but I will try to explain what we did on a students '76 buick.
The broken area at door opening.
The window/door seals area of your favorite hardware store will have thin rubber strips 1/2" , 3/4" ,1" etc wide ,that have grooved channels on both sides , we used this to fill in the gap, after trimming the upper overlapping panel back to make the rubber strip fit.
The grooves on the sides held it in place. Sorry I don't have photo's.
Then remove all the trim, clean it really well, then clean it again, then dye it all one shade of matching color.
The student was not after showroom stock 100% show car points type fix. so it looked good and fixed the issue, other than some of the warping, but was not "correct"
We have also used the fleece and fiberglass resin to form parts or to cover missing parts of a plastic part.
Old Feb 21, 2021 | 06:52 PM
74 will work on a 76 cutlass s?
Old Feb 21, 2021 | 08:11 PM
rocketraider's Avatar
Oldsdruid
74-77 F37 and G37 body styles will work.
JOHNNYOLDS442
Dec 18, 2020 09:03 AM
JOHNNYOLDS442
Sep 8, 2020 01:40 PM
dedsleds
Dec 18, 2019 01:30 PM
j808702
Oct 31, 2016 07:50 PM
bonezarally
Jul 26, 2011 04:45 AM
