1973 Corvette wheel and hub a direct bolt on for '72 Cutlass?
Old Apr 8, 2017 | 07:31 AM
Tfitz's Avatar
I have my eye on a complete steering wheel for a 1973 Corvette, from horn button to hub. But I'm reading conflicting info online that Corvette wheels fit GM cars fine and that they don't. I want it for my Vista Cruiser. Please help! Will this wheel and hub bolt directly onto my stock 1972 Vista Cruiser?
Old Apr 8, 2017 | 08:27 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
The vette wheel (C2&C3s) generally has a deeper offset but should work The base adaptor and wheel should bolt up. Measure your spline and measure the collar depth of the olds and compair. Call Ecklers or Corvette Central tech lines and ask. Give Ididit a call. They should be able to give you a definitive answer. Are you looking at the 3 spoke brushed aluminum wheel?
Old Apr 8, 2017 | 08:32 AM
Tfitz's Avatar
yep, just your typical 3-spoke.
Old Apr 8, 2017 | 09:02 AM
Tfitz's Avatar
I ended up getting the wheel. Even if it doesn't fit, I got it cheap enough that it isn't a big deal if it doesn't fit perfectly. It's going on a complete beater anyways.
Old Apr 8, 2017 | 09:08 AM
If it's this style hub, it bolts right on. As noted, the dish of the wheel might put it closer to your chest.
Old Apr 8, 2017 | 06:14 PM
Tfitz's Avatar
I only have a rear view of the hub since the wheel is mounted to it in the pictures, but I'm 99% sure that's it.
Also, I just scored a 4-spoke sport wheel for a cool $35, so I'm going to just cannibalize parts from this Corvette wheel to mount onto the sport wheel, and probably sell the bare Corvette wheel. Or I might keep it on ice in case I feel like changing things up. Decisions, decisions.
Old Apr 22, 2017 | 05:30 PM
Tfitz's Avatar
For anybody who happens to have the same question I did, the answer is yes. A C3 Corvette steering wheel hub fits a 1972 cutlass, and a bunch of other stuff. The hub is the same.
VinMichael
Jan 19, 2016 03:11 PM
marxjunk
Feb 24, 2015 06:45 PM
BILL DEMMER
Feb 16, 2013 09:49 PM
69350rocket
Aug 8, 2011 02:52 PM
88 coupe
Jul 31, 2008 08:54 AM
