1972 cutlass s shifter won't fit
Old Apr 25, 2020 | 01:55 PM
72Cutlass_442's Avatar
Hello all,
I have a 1972 Cutlass S that i am converting to a manual transmission. I am using a 1971 muncie 4 speed and a Hurst shifter. For some reason, the shifter is hitting the cosole. It appears that when I shift into 4th, it pushes my console back about 2" further back than it should be. What is going on? Please see pics. Any help would be much appreciated.
Neutral position
Shifter type
It's in the center
4 gear is pushing the hump back
Neutral position
4 gear.
The front attaching plate doesn't make contact with floor
Old Apr 25, 2020 | 02:09 PM
4speed455's Avatar
The 4 speed console should be cut out at the bottom to clear the hump. The ones I saw didn’t look this clean, they actually looked like they were broken and missing a big chunk.
Old Apr 25, 2020 | 02:21 PM
The console has been cut to accommodate the shifter hump.
Old Apr 25, 2020 | 05:16 PM
Guy Fillinger's Avatar
Going through a similar problem on my 65 442. do you have clearance in 1st or 3rd ? If you do my questions are is the Shifter mounted in the correct holes? If yes do you have the right adapter plate for you transmission? I would start there, also can you pivot your Shifter forward to give your self more clearance.
Old Apr 25, 2020 | 07:47 PM
I do have clearance in 1st and third. Hmmm I wasn't aware that I could pivot the ******* from its current position. I'll take a look tomorrow to see if the plate has that attribute. That's really all I need to do is have it face more forward. That might do the trick! Thanks!
Old Apr 26, 2020 | 08:59 AM
I believe it was the mounting bracket. I ordered the proper one for a my car and it looks nothing like the one that is currently one the trans. I'll post an update when the new one gets here.
Old Apr 26, 2020 | 09:27 AM
You mean I might have got something right!!! Boy that will be the first time in my life.
Old Apr 26, 2020 | 04:24 PM
Haha I hope so!
Old May 8, 2020 | 08:00 PM
Hey 72 how did you make out with your shifter?
Old May 11, 2020 | 06:13 AM
It was the mounting bracket. It all fit perfectly once the correct plate was put on. The shifter handle sits nicely in the center of the console, and the console site right where I was thinking it should. Thanks again for the help!
tru-blue 442
Mar 28, 2020 03:01 PM
Nickyloves442s
Feb 22, 2020 05:30 PM
shockrebuild
Oct 31, 2019 08:10 PM
BeenThere
Mar 22, 2019 12:56 PM
montvaleplace
Feb 29, 2016 08:40 PM
