1971 Oldsmobile 442 - Seat Belt doubt
Hi guys, how are you doing?
I have a question about the seat belts, let me explain.
I had to remove the seat belts to properly align the interior carpet. When I went to put them back, I found that the passenger seat belt locks up and I can't pull it up. However, if I remove the plastic cover, it moves up and down without any issue.
Is there a way to adjust the seat belt lock so that it's just one inch higher? That's all I need for it to work properly.
I'm attaching a video in case I didn’t explain it well and so you can better understand what I mean.
Thanks in advance.
Regards
Video:
Thanks in advance.
Regards
Video:
Either way, it's likely the ratchet locking mechanism can be adjusted so it works properly. I would take the plastic cover off and inspect the mechanism to determine why it's doing that.
No, before removing the plastic cover it was working correctly, which is why I believe it must be something related to the adjustment.
I’ve looked at the mechanism, but I didn’t see anything that could be adjusted — I’m not sure if there’s an easy way to do it.
Thank you.
Regards
I replaced the carpet & seat upholstery in my '71 CS convertible & this happened to one of my seat belts. I wish I could explain to you in "detail" exactly what the issue was because I don't recall. However, what I "do" remember is this. I think what happened was...note again...I "think" I may have mixed up the two seat belt mechanisms when I went to reinstall each one. IIRC, I believe they are geared to each side. I think I swapped either the left for the right or I actually turned them around in their respective holes in the floor pan. Wish I could recall exactly, but I'm nearly certain I installed them incorrectly - like backwards or left-to-right, right-to-left.
I've gone over this several times and I can’t get it to work properly. I’ll try to take a photo when I have the time. Basically, the belt is coming from the part next to the seat, not from the door side. I’m not sure I’ve explained myself correctly.
I’ll take a picture and show it to you. On another note, the housings have the silkscreen labels "R" and "L" on the inside, so I don’t believe I made a mistake in that regard.
I’ll let you know.
Thank you.
Regards.
