1971 Console Painting
Old Jun 14, 2016 | 04:19 PM
geoff442's Avatar
I'm looking to restore a center console, I need some advice on paint selection and prepping the console. The console is brown in color and I want to paint it black. Any advice would on the console would be much appreciated.
Old Jun 14, 2016 | 04:29 PM
For hard plastic parts I used SEM vinyl paint. Clean the parts very well to remove all dirt, grease, and oils, then spray them with light coats.
Old Jun 14, 2016 | 05:32 PM
ELY442's Avatar
Originally Posted by fun71
for hard plastic parts i used sem vinyl paint. Clean the parts very well to remove all dirt, grease, and oils, then spray them with light coats.
x2
Old Jun 15, 2016 | 06:46 AM
X3 on the SEM, however, you MUST get the plastic completely clean. Use a toothbrush or similar brush to scour the grain in the plastic. Once dry, use the SEM prep solvent before painting.
Old Jun 16, 2016 | 01:42 AM
geoff442's Avatar
Thanks for the advice, what type of black paint shoul I use semi gloss, or glossy.
Old Jun 16, 2016 | 06:00 AM
allyolds68's Avatar
SEM Landau Black Part #15013
Here's the last one I restored. It was originally brown.
https://classicoldsmobile.com/forums...-restored.html
As Joe said, use the SEM prep and clean it well with a brush
Old Jun 18, 2016 | 03:00 AM
geoff442's Avatar
Thanks for the info it saves a lot of unnessary experimental work. What should I do with the metal moulding that wraps around the console, it looks like the tabs slide through then are bent to hold it in place. Can tha metal be polished ?
Old Jun 18, 2016 | 05:37 AM
RetroRanger's Avatar
72 Olds CS
I think that aluminum price is anodized, it can be removed and re installed if your careful
Old Jun 30, 2016 | 07:08 PM
Shradezz70S's Avatar
I am restoring one converting it to a 4 speed. I removed that trim pice and sanded the plating off with 320. Then in worked finer 400,600,800,1500,2000 grit. Then rubbed it out with mothers and it looks perfect.
bigmattg1
Oct 7, 2013 02:05 PM
72notchback
Feb 22, 2013 06:49 AM
Prophe'c
Oct 22, 2010 09:16 AM
dallasite21
Mar 29, 2010 07:54 AM
mv213
Nov 24, 2009 10:32 PM
