1970 Deluxe Seat Belts
Old Jan 16, 2013 | 03:56 PM
69'442's Avatar
Anyone know if you can take the top off a regular seat belt buckle and put on the stainless deluxe kind. Are the buckle parts the same and just the covers are different or is the whole buckle different?
Old Jan 16, 2013 | 04:03 PM
stevengerard's Avatar
I am pretty sure the guts on those are the same. Just different covers. Deluxe are the brushed metal covers. Some deluxe sets have smaller sized buckles for the front passenger lap belts and use the larger buckle for the shoulder belt and back seat occupants.
Old Jan 16, 2013 | 04:13 PM
69'442's Avatar
Really, smaller buckles for the front lap belts? Mine are all the same size.
Old Jan 16, 2013 | 07:04 PM
I have only seen them on a few cars with Bucket seats. not sure what determined the smaller buckles. In the documentation I have for ordering it only shows deluxe it does not distinguish between small buckles and large buckles
Old Jan 17, 2013 | 12:03 PM
Olds442redberet's Avatar
I just changed out my original buckles and put them on some seat belts I bought from a fellow Olds guy on this forum. Nothing to it. If you need I'll post pictures of the process.
Old Jan 17, 2013 | 12:08 PM
69'442's Avatar
Did you change the whole buckle or just the cover?
Old Jan 17, 2013 | 12:52 PM
Just the cover and the top part of the pressure plate. Very easy to do with a medium size screwdriver.
Old Jan 17, 2013 | 01:20 PM
My camera battery died. I can get you pictures tonght. But if you want to work on it now you can take a medium flat tip screw driver and insert it between the base and the top in the rear (opposite the insertion side) and pop the corners. It will snap back together during reassembly.
Old Jan 17, 2013 | 01:56 PM
Pictures of the seat belts. As you can see, a screw driver and a little pressure and the top pops right off. The interior mechanisms are a little more complex, but if I can do it you can too. Besides, you don't need to take them completely apart to change out the base/deluxe covers.
Old Jan 17, 2013 | 02:03 PM
69'442's Avatar
Thanks, I will give it a try.
Old Mar 6, 2013 | 10:35 AM
69'442's Avatar
I changed my covers over to the deluxe ones. I have the 2 smaller female buckles for the bucket seats. They also use a different narrow male end retractor which I have. My standard retractor covers don't fit. On a 70 do the covers that belong on the deluxe belts have the small doors on the back of the covers?
Old Mar 6, 2013 | 11:02 AM
Mine did not have the door, I have seen those before but I can not remember what application those are from. Not sure why your covers do not fit. Mine fit fine. Hmm......
Old Mar 6, 2013 | 11:07 AM
69'442's Avatar
How did you get the covers off the larger male end retractor? I couldn't slip the covers off past the male buckle.
jcmoretti
Jul 11, 2018 03:07 PM
Drbigblock
May 12, 2015 05:32 AM
briane
Nov 15, 2014 03:46 PM
6OLDS4427
Sep 15, 2014 08:43 PM
NDERISE
May 3, 2013 09:01 PM
