1970 442 soft top assy removal
Old January 12th, 2009, 12:36 PM
hdvettes's Avatar
I am getting ready to repaint my '70 442 convertible. I want to remove the complete soft top assy. Does anyone know if the rear bow is detachable? The top assy is wider at the back than the well opening so it will seal when the top is up. How do I get the assy out after everything is loose? All help is greatly apprieciated.
You can email any photos to me at bigvettmike@aol.com
Thanks in advance for any help.
Mike
hdvettes is offline
Old January 17th, 2009, 11:14 AM
68conv455's Avatar
Are you talking about the area below the rear window? If you are, that is the rear tack strip and it is bolted to the body below the pinchweld molding and above the water gutter. On my 68 cutlass it is a 2 piece design.
68conv455 is offline
Old January 18th, 2009, 08:33 PM
hdvettes's Avatar
Thanks, On my car there is a rear bow that bolts to the top frame on both sides. After unbolting it there is still not enough clearance to remove it. How is your attached?
Thanks for the information,
Mike
hdvettes is offline
rcktdoc
April 16th, 2014 04:16 AM
teknik22
March 25th, 2014 03:38 PM
oldsdroptop
January 1st, 2010 06:30 PM
rileyborup
May 17th, 2009 12:59 AM
Nailhead 88
January 7th, 2008 02:07 PM
Quick Reply: 1970 442 soft top assy removal
