1969 Front Bench Seat
Old Jan 10, 2022 | 01:33 PM
grannys442's Avatar
How are the seat backs removed (ie dislocated) from the seat bottom?
I’ve read through previous posts re: the bench seats, but still don’t understand how.
Does this chrome hinge pivot cover need to be removed to reveal a clip or pin or something?
Figured better to ask wise men rather than tearing something up. Thsnks
Old Jan 10, 2022 | 02:20 PM
Yellowstatue's Avatar
The chrome button pops off and there is a clip to remove on that stud. "E" clip ?
Old Jan 10, 2022 | 03:05 PM
From the 1969 Fisher Body Manual.
Old Jan 10, 2022 | 04:00 PM
grannys442's Avatar
Im not knowledgable on these bench seats. Would my seat in photo be a type “39” as referenced in the excerpt from the Fischer manual?
i managed to remove the outer hinge cover (twas a PIA) and separate the outer hinge. I had hopes i could then simply lean the upper seat back forward and extract it from the center hinge. But she aint budging.
thanks for the help thus far.
Old Jan 10, 2022 | 04:08 PM
"39" is a 60-40 seat. yours is not. Read left paragraph, tilt forward and up and carefully separate
Old Jan 10, 2022 | 04:38 PM
Your car is a 2DR.
That is not correct. "39" refers to the body style. The statement is "'39' Style Full Width Seat and Buick, Oldsmobile, or Cadillac 60/40 Seat with Notch Down Arm Rest". This section applies to ALL bench seats with arm rest (except the Strato Bench that is covered separately). The 39 style is the Holiday Sedan (four door hardtop) which is the only body style available that year with a fixed back bench seat and an arm rest.
Old Jan 10, 2022 | 09:18 PM
grannys442's Avatar
Thanks. Fold forward and lift up was the trick. Below is a picture of the keyed center pivot…for the next lost guy like me.
Old Jan 10, 2022 | 09:20 PM
grannys442's Avatar
Old Jan 10, 2022 | 09:33 PM
So one thing that wasn't pointed out was use the thinnest metal what ever that you can. Thinner than a butter knife. Make it wide. Every size putty knife should be in your toolbox. Do not pry with a small thin screwdriver. The plastic is thin and the chrome will chip as soon as you break the plastic. Be patient with it. Better in the long run.
Old Jan 11, 2022 | 11:19 AM
acavagnaro's Avatar
Those tears in the vinyl aren't too bad. The rest of the seat looks to be in great condition. Is your plan to recover all 3 pieces (both backs and bottom)? I have a parchment version of that seat with the same driver's side wear, although mine's worse than yours. My seat cover repair was a carefully placed white bath towel (for now).
Good luck.
Old Jan 11, 2022 | 12:36 PM
grannys442's Avatar
The interior of this car is absolutely pristine except for those tears in the front seat. This car belonged to my grandmother (she’ll be 100 next month) and has 68k miles always kept garaged.
I’m trying to be good steward and preserve as much a possible.
Im hoping to find a good upholstery shop in FortWortj area who’s willing to “attempt” piecing in some new vinyl in the damaged areas. I’ve ordered some samples from SMS fabric.
ive talked to a couple of shops and they understandably can’t commit without seeing/touching the aged covers. If noone is willing, i may just leave the damaged covers alone rather than recover. I’ve learned it’s not about the money when it comes to proper stewardship of an unmolested car.
The simple route here would be to jump in guns a blazin, order a Legendary cover and drop it off at the upholstery shop and pat myself on the back. But not so fast. It’s only original once.
Being an old guy brings a different perspective. The once ugly is now attractive.
Old Jan 11, 2022 | 05:11 PM
tnswt's Avatar
'70 4-Speed W Machine
....This car belonged to my grandmother (she’ll be 100 next month) and has 68k miles always kept garaged......
An early Happy Birthday and congrats to that soon-to-be centenarian, and good luck with your seat project.
Old Mar 16, 2022 | 05:42 PM
grannys442's Avatar
Just picked up the seat. The uphosterty guy was able to save the pleated sections and just replace the damaged areas that were in a few sections of the smooth vinyl. I’m happy that the seat retains the majority of the original material. Now to figure out how to reinstall trim without fouling up his great work.
Old Mar 17, 2022 | 04:05 AM
That looks great!!!
Old Mar 20, 2022 | 10:39 AM
grannys442's Avatar
My grandma ( this car’s original owner) turned 100 last month and still livin’ with my dad.
To borrow some of her rural oklahoma vernacular:
”The divan’s repaired and back in the front room”
Old Mar 20, 2022 | 11:48 AM
tnswt's Avatar
This is a beautiful read. Your intentions are outstanding with regards to your Grandma's 442. Will there be a celebratory party when you are done and she rides in it once again? Heck, it may be she drives and you shotgun!
Old Mar 20, 2022 | 05:40 PM
Eddie Hansen's Avatar
now that is a phenomenal idea! Can you imagine !
miksan
Aug 19, 2022 08:57 AM
Robin1969
Sep 2, 2019 11:15 AM
1968CutlassSupreme
Jan 31, 2014 06:26 PM
camshaw
Oct 21, 2013 06:56 AM
bmwashington
Apr 12, 2011 09:54 AM
