1968 olds 442 seat belts
Old Jan 12, 2014 | 08:52 AM
wisniows's Avatar
Im putting my interior together since I was not the one who disassembled it I have a question on the seat belt install first is the buckle positioned on the inside also is there 2 or 3 seat belts for the rear seat I would really appreciate a picture if anyone has one of how they are mounted
Old Jan 12, 2014 | 04:06 PM
69442C's Avatar
Here's 2 photos of a 69 convertible rear seat and the belt arrangement should be the same for your 68.
Brian
Old Jan 22, 2014 | 11:22 AM
wisniows's Avatar
68 442 seat belts
by the way just wanted to tell you your interior looks great i was just wondering if the center seat belt buckle is on the left or the right side when the passenger is sitting in the center position of the seat, in your picture i see it to be on the right side of the center passenger, i looked in my new gm vehicle and i noticed the buckle was positioned on the left side do you know if gm changed the location of the buckle from 68 to present years and are you sure your buckle is in the correct position in your vehicle, thank you again for that quick response
Old Jan 22, 2014 | 01:02 PM
69442C's Avatar
Thanks. The arrangement of the belts is the way they were when I received the car and I put it back the same way after I restored it. I had another 69 442 several years ago and the rear seat belts were done in the same manner.
Old Jan 23, 2014 | 12:49 PM
wisniows's Avatar
I spoke with someone at fusick and they guy told me he wasn't sure of what side the buckle is on but he also believes the buckle is on the right side,i just got confused when I looked at my newer vehicle it was positioned opposite side thanks once again for the help hopfully I will be able to assist you
Old Sep 26, 2018 | 07:00 AM
Billyaxe's Avatar
On installing the front seatbelts in a 1968 442 with bucket seats and a console, is it recommended to remove the seat? And how about the carpet being tucked under the console. Should the console be loosened to get the carpet out? The previous owner installed new carpet so there are no mounting holes thru the carpet. That would have made it easier. —Billy
frozencaveman
Vista Cruiser & Wagons
Aug 29, 2018 01:06 PM
olds70supreme
Aug 5, 2018 04:43 PM
brandongreen@gmail.com
Mar 19, 2017 04:44 PM
miko442
Dec 26, 2015 01:41 PM
68ragtop
May 21, 2008 04:37 PM
