1968 Heater Control slider
Old Apr 26, 2016 | 05:39 AM
Aron Nance's Avatar
On trip back from the Zone Show 2 weeks ago, torrential rain occurred, and never could get the defrost function to work correctly. In sliding the heat/cold "slider" back and forth, something "happened". Now, it feels "loosey-goosey", and will not go to full left position. Looking at the manual, trying to figure out if the wire control came off the lever on the upside of the heater box, or off the back of the heat/cold control itself in the dash. Anyone experience this? I plan on removing the glove box innards and hope to be able to "see" the lever on top of the heater box. As to the lever on the back of the dash control, reaching up/in there feels like the whole thing is not attached. Appreciate any suggestions, as usual. Not able to get under the dash like I used to, don't understand that.....................hmmmmmmm.
Old Apr 26, 2016 | 07:08 AM
Aron,
You've got it. The wire is not connected at one end. If you're lucky, it simply came off the post or the clamp that holds the sheath came loose. If your luck is like mine, however, the wire has broken at one end or the pin that it fits over has broken.
Old Apr 26, 2016 | 08:15 AM
Chesrown 67 OAI's Avatar
Aron,
Ive got an extra dash control unit from my 68 F-85 if you need one and it will workin your car?
Tweed
Old Apr 28, 2016 | 03:03 AM
Aron Nance's Avatar
Tweed: I plan on pulling the glove box etc. and checking out my problem today/tomorrow, and will get back to you with the possibility of purchasing your "extra" unit.
THANKS!
Aron
Old Apr 28, 2016 | 05:11 AM
allyolds68's Avatar
THANKS!
Aron
Aaron,
If it's non A/C you can get to everything without pulling the glove box. You can reach behind it and get the cable back on. My cable pops off at least once a season. There is one connection pin on the back of the heater control that's notorious for breaking. I have two spare controls and it's broken on both
Old Apr 28, 2016 | 09:58 AM
Octania's Avatar
The cables work a lot better if they ever, EVER get lubed.
Old Apr 28, 2016 | 01:50 PM
Aron Nance's Avatar
The glove box is "out", and I can see (finally) the lever assembly on top of the heater box; hooked up, and looks/feels functional (it IS an A/C system from the factory). I can move it back and forth, manually, and hear the door inside opening/closing. Looks as if the problem is going to be "behind" the dash mounted slider controls, which seems to jam about 2/3's way headed back to the left. Any thoughts on removing that whole panel, EASILY? Will also lube the cables I can get to in the process. Thanks for all the responses.
Aron
385ci1969
Nov 23, 2014 05:06 PM
costpenn
Oct 4, 2014 04:39 AM
dnmfranco
Sep 22, 2014 09:01 PM
RPMRestoAndCustom
Apr 10, 2012 12:40 PM
lmarquette
Feb 17, 2012 05:28 AM
