1963 Dynamic 88 fuel gauge removal
Is there any way to remove the fuel gauge out of a 1963 Dynamic 88 without removing the cluster?
Just got this ride and im trying to diagnose my fuel gauge/sender and wanted to take it out and inspect rhe whole thing.
Thanks!
Thanks!
The easiest way to get to the gauge is to remove the cluster.
However, you may not need to do that to diagnose the gauge.
Remove the wire from the sending unit on the gas tank.
Turn the ignition on and see if the gauge registers full or even over full
Ground that wire to a good ground, and the gauge should read empty.
