68 hurst stripes
Old Nov 6, 2010 | 05:45 AM
scr8p's Avatar
68 hurst stripes
what's the approximate width of the white pin stripe on these cars? we have a pin striper coming on monday to do the 68 hurst were building and need to give him some kinda of a dimension.
i would think they'd be the same as the 69, so maybe a 69 owner could chime in.
thanks in advance.
Old Nov 6, 2010 | 06:21 AM
sicky olds's Avatar
NôôB
the black pin stripe on mine is right at 1/8th of an inch. not sure if that is correct width but thats what i got
Old Nov 6, 2010 | 06:28 AM
arodenhiser's Avatar
STOP call'n it a Chevelle
Have a look here....
https://classicoldsmobile.com/forums...imensions.html
Adam
Old Nov 6, 2010 | 06:40 AM
sicky olds's Avatar
NôôB
did it mention the thickness of the pinstriping though? i did not see any but it ould be cause i am half blind as well lol.
Old Nov 6, 2010 | 08:07 AM
Aron Nance's Avatar
When we painted the Silver Bullet I went over to Joe Munoz's house and measured his REAL '68 H/O, and the stripes ae 1/8", for sure. If you need any of the other dimensions, I have them saved, and would be glad to post.
Old Nov 6, 2010 | 08:13 AM
sicky olds's Avatar
NôôB
then its the same on the 69 as well i would say . just pointing out the obvious here lol
Old Nov 6, 2010 | 09:15 AM
derek nesdoly's Avatar
olds..older..oldest
The Striping Bible
The New Revised King Joe Version of the" Striping Bible " can be found in a thread search of this sites archives...key words STRIPE/PADAVANO. It is above reproach and considered divinely inspired Derek
Old Nov 6, 2010 | 02:18 PM
scr8p's Avatar
Originally Posted by arodenhiser
i know of that thread. i even copied the attached images. but i must have overlooked the pin stripe dimension last time i read it.
thanks again.
Old Nov 6, 2010 | 05:21 PM
Yeah, I think your fender stripe and rocker panel measurements are the same. The hood lines are different, just pointing out the obvious here lol.
Adam
Old Nov 11, 2010 | 08:16 AM
sbFALL63's Avatar
SCOTTYB HERE I'M ALSO RESTORING 68 H/O CAR #72 W-45 COULD USE DIGITAL PICS OF ANY ALL START/STOP AREAS ESPECIALLY ANY TAKEN WITH A TAPE MEAS. OR RULES WHREE STRIPES TAPER OFF LWR QUARTERS, DOOR JAM TERMINATIONS, HOOD DETAIL... THX sbaldridge@eid.org 530-333-3558
Old Dec 22, 2010 | 07:41 AM
sbFALL63's Avatar
Stripes 68 h/o
NEED ANY ALL I CAN GET, I HAVE CAR #72 PAINT WAS OFF, HAVE BASIC STRIPE LAYOUT, BUT NEED QTR PANEL TAPER , DOOR JAM END POINTS AND WAS RED OXIDE PRIMER USED AS BASE FOR SILVER? SCOTTYB any pics of detail would help thanks sbaldridge@eid.org 530-333-3558
Mar 21, 2014 11:57 AM
Big Mikey
Hurst/Olds
Mar 5, 2013 12:56 PM
firefrost gold
Hurst/Olds
Jun 13, 2012 07:28 PM
Redhawk1
Aug 25, 2005 07:08 PM
<kjmoore66@hotmail.com>
Jun 24, 2003 09:50 PM
