The H/O air cleaner shared the actuator, flapper and rod from Ford, the actuator should have a 'FOMOCO' stamp on it.
Demmer/Hurst came up with an upper assembly that was either tacked onto the top of the bottom can for the 1969 H/O or same exact one tacked to the underside of the hood for the 1969 AMC Scrambler.
The CobraJet top, while using the same parts was a little different.
The actuator is still available, I do not know if there is a part number/identifier on it.
