1969 H/O Air Cleaner Top
Old Mar 1, 2026 | 03:46 PM
briane's Avatar
Can anyone share experience with the '69 H/O metal air cleaner top assemblies Bob Anderson had made?
Thank you.
Old Mar 1, 2026 | 06:53 PM
Cfos0031!'s Avatar
From the couple I have seen of his they are excellent! Only way to tell is no part number. The orignals were actually Ford units.
Old Mar 2, 2026 | 10:13 AM
1969Hurst's Avatar
The H/O air cleaner shared the actuator, flapper and rod from Ford, the actuator should have a 'FOMOCO' stamp on it.
Demmer/Hurst came up with an upper assembly that was either tacked onto the top of the bottom can for the 1969 H/O or same exact one tacked to the underside of the hood for the 1969 AMC Scrambler.
The CobraJet top, while using the same parts was a little different.
The actuator is still available, I do not know if there is a part number/identifier on it.
tt455
Hurst/Olds
52
Mar 4, 2024 06:02 AM
jimvbills
Aug 29, 2016 12:00 PM
don_69sbo
Aug 21, 2011 08:18 PM
slowolds
Hurst/Olds
Apr 27, 2010 04:41 PM
Willy69f85
Dec 4, 2008 07:59 PM
