69 Hurst/Olds vacuum routing
Hey Guys, I have a question in the assembly manual the 1-5 section & the 6-1 section the vacuum routing is confusing, my car has A/C now my car only had the nipple for the water hose but they also do the vacuum diaphragm on 1 picture which makes sense it would shut off the hot water going to the heater box so the A/C would work properly actually the A/C wouldn't have heat generated from the water hose the Diaphragm would shut it totally off THAT WOULD MAKE SENSE and that Diaphragm is actually listed with a gm part #
what is right (ANYBODY)? I'm confused again appreciate any helpThanksAlsmith787
A/C hot water diaphragm vacuum hose
Yes this is the vacuum actuated valve at the back of the engine block passenger side from what I read in the assy manual it's the #3 vacuum hose that has a white line on it???????? Can't find it or it's there & I'm missing it? The valve which I bought NOS part has a threaded end the other end has a hose end, then the Round Diaphragm at 3rd end which has a vacuum tube connection coming out of the middle what vacuum hose goes there AND more importantly DID the '69 H/O Have this valve from stock off assy line or did it just have a hose going on a fitting ONLY by the way this isn't a small valve it's a pretty tall valve is that right or was there a compact valve just a simple question honest.
ThanksAlsmith787
ThanksAlsmith787
