69 h/o question
Old Oct 5, 2009 | 09:46 PM
fizzy55's Avatar
69 h/o question
did the 69 h/o with air have a heat riser valve in the ex manifold? also would anyone know the center to center drive shaft length? thanks in advace.
Old Oct 15, 2009 | 07:51 AM
junior supercar's Avatar
thought all 69s got the heat riser valve in the exhaust manifold. but yes is the answer to your first question
Old Oct 15, 2009 | 10:26 AM
Funny you should ask
I was just thinking the same thing the other day. Mine does not have it. But I do not kow if it should or not. If it is spose to have one .......I'm not sure if it would work? Then again maybe it could?
Joe?
Jeff?
Wmachine?
Old Oct 15, 2009 | 05:38 PM
it should have one. I have the benefit of seeing a senior preservation winner car darn near anytime I want. I've even taken it down the strip at the Pure Stock Drags. It's an a/c car and has the heat riser for those curious. If it's the Jeff I think you are referring to, he knows this car too
the W/Z, 69 was the only year the driver side had the heat riser valve. the 70-72 did not have it. other than that the W/Z manifolds are the same.
Old Oct 16, 2009 | 04:50 AM
"Driver's side"????
Old Oct 16, 2009 | 07:16 AM
citcapp's Avatar
I saw a set at the Monroe swap meet with the heat riser on the drivers side for a $100.00 last weekend, almost bought them, now I wish I had
Old Oct 19, 2009 | 01:06 PM
The learned Wmachine jes straightened me out. I was thinking heat riser. [To the snorkle] While ya'll were talking exhaust heat riser.
Sorry, I stay a might confused.
Old Oct 19, 2009 | 01:17 PM
68CO-HURST's Avatar
Heat Riser for 1968 H/O w AC?
Does this also mean that the 68 H/O with AC should also have this heat riser? Same as 69 H/O? It doesn't look like it would fit with AC bracketry in the way.
Old Oct 19, 2009 | 02:06 PM
wmachine's Avatar
Trying to remember member
'68 442s with AC have a snorkel that points more toward the front of the car to clear the AC brackets. But the '68 H/O has a much different air cleaner. Never the less, the '68 *should* still have a "stove pipe", but someone that knows for sure would have to confirm that.
Old Oct 19, 2009 | 06:11 PM
69ho aurora's Avatar
The 68 and 69 big block a-bodies (442, H/O, and Vista) had (almost) completely different heat riser assemblies by year to go along with the different manifolds they used.
The 68 assembly had a common shroud all the way around the exhaust manifold, a common stove pipe and a different second adapter depending on whether it had a/c or not. While the W30 and H/O had a different air cleaner, they shared the whole riser assembly with the 442 (and a/c vs. non-a/c).
For 69, there was a completely different (simpler) shroud and then a single pipe (except for the W30/W32 cars which had a unique stove pipe and the same second adapter used on the 68s). For 69, the H/O used the same setup as a regular 442.
yeahbuddy
Dec 19, 2011 08:40 PM
