So I did a search on this but still have some questions. How many parts are there to this air cleaner assembly? I see there is the base, the flapper and actuator, foam, but from the pictures I found in the search there seems to be a piece in-between the base and flapper. Is there a piece the flapper sits on, and is it available? I can't figure it out with the foam covering it on pics I found? Also I see posts of an air cleaner lid for this, where would that go. I see there is a reproduction of the flapper which I know fits the Rambler also. Pictures would be great and answer most of my questions. Thanks so much.
Some years ago someone was making a reproduction. It was very easy to spot on a engine. I think they were charging about $600.00. If you are looking for the real thing be prepared to pay major money for it. If you can find one, I consider it as one of the Holy Grails of the 69 H/O along with the "D" code heads and Intake Manifold. Good Luck
Thanks for the pics. There is someone selling the flapper but what I was trying to figure out is how this would work. I guess this would have to be mended to that piece above the base which seems to be rare.
That part you show I believe is for the AMC SC/Rambler which mounts up into the hood. I believe it was the same piece when made of metal that was fused to the metal adapter piece on the 69 H/O. Note that the rough finish on top of the fiberglass unit. It was designed to be hidden when mounted into the hood of the Rambler.
Yep, you can see with a top without the foam where that is the same piece attached to the upper 'dome' that fits into the base. The actuator should be a FoMoCo part... There was a guy that was restoring them for the Ford Cobra Jet community, but I do not think he is doing it anymore.
