1983 Hurst T Top Weatherstripping
Old Jun 8, 2011 | 02:15 PM
Franks442's Avatar
I am the original owner of an 83 H/O. I want to replace the weatherstripping in it's entirety. There is the heavy rubber stripping that sits above the visors in the channel, the heavy rubber stripping across the side of the door windows, the stripping that runs down the side of the pillar. In addition there is what appears to be a "peel and stick" type of foam that is actually applied to the glass of the tee tops itself that is drying out and definitely needs to be replaced. Does anyone have a good source for the stripping, particularly the soft foam "peel and stick" foam that goes on the underside glass surface. Any help is greatly appreciated.Thanks in advance all.
Old Jul 12, 2011 | 09:17 AM
snowballs442's Avatar
Resident Eskie
www.steelerubber.com Might still be able to get some from GM. I would try that first. More expensive but that will fit for sure.
Old Jul 12, 2011 | 09:38 AM
Aron Nance's Avatar
Don't know if Steele Rubber carries that particular item, but they are on the net. They are great people to deal with!!! Replaced all the rubber on the Silver Bullet, and what they sent for the rear window (think that was it) was exactly right. They had me mark the one they had sent, send it back, made a new one correct for '68's, and sent me the new version, all at their expense!!! Cannot get better than that, in my opinion. Highly recommend them.
Old Jul 12, 2011 | 11:18 AM
69HO43's Avatar
The stick on seal is the T-top secondary seal. GM part number 20139617. Still shows as a good number at your GM dealer. Retail price is $38.95 each.
Old Jul 13, 2011 | 12:47 PM
Franks442's Avatar
Thanks to all for your responses
I have owned a lot of 442's etc over the years and have been able to source most everything I ever needed. But these Tee Top strips have been a tougher one. I will check with all of the recomended sources and again thanks for the support.
Frank Larkin
66 442
83 H/O
Old Jul 13, 2011 | 03:17 PM
Resident Eskie
Hey wait a minute, dont go away. You keep us updated on what you do. You do have good taste in cars and a good line up.
Old Jul 23, 2011 | 06:13 PM
Franks442's Avatar
Tee Top Updates
Absolutely I will keep everyone updated. And thanks for the compliment.
Frank
spayne
Hurst/Olds
34
Sep 23, 2016 06:24 PM
75hurstoldsW-30
Apr 1, 2014 03:13 PM
dz442
Nov 2, 2013 01:23 PM
dz442
Nov 2, 2013 01:09 PM
