69 hurst hood
Old Jun 26, 2011 | 07:28 PM
69OLDSCUTCONV's Avatar
69 hurst hood
when they made the hurst hood did they cut a hole and attach the glass scoop. did they just use a 442 hood or was it something special.
does anyone have any pictures ?
Old Jun 27, 2011 | 07:12 AM
Yes, it's simply a metal 442/Cutlass S hood with a hole cut out under the bolt-on scoop. The hole is actually rather roughly cut. There are four drilled holes in the corners connected by sawn straight sections to make a crude rectangular hole. It ain't pretty.
Old Jun 27, 2011 | 09:20 AM
Do you have the size of the rectangle and any reference distances from any spots on the hood. Aslo if anyone else has any info or pictures of the cutout that would be great. Thanks
Old Jul 13, 2011 | 05:49 PM
firefrost gold's Avatar
do you still need the cut out info I will go get mine if so .
Old Jul 13, 2011 | 06:16 PM
HurstOlds1775's Avatar
Here are a few pictures to help you out with the placement. If I remember the very rear tip of the scoop (on top of the hood) is 19" from the rear of the hood chrome. And the cut out is 5-1/2" wide by 6" long. It is a rought cut out with drilled holes at each corner like Joe said. Hope this helps you.
Old Jul 13, 2011 | 07:38 PM
If you pull the scoop off i wonder if you can see the jig or air saw mark
from the cutting ?
Old Jul 13, 2011 | 08:26 PM
I had another hurst owner tell me that it was a 6" x 6" square hole. and the 6" was centered in the hood and 21" from the back of the hood. Thanks for the picture that helps alot. if someone else has any location or sizes let me know. Maybe cutting 900 plus holes they were a little crude in layout and cutting.
Old Jul 14, 2011 | 04:49 AM
They look like 4 holes were drilled in the corners then the cut was made.
My drawing says 5 3/4" wide 6" deep
25 1/8" from side of hole to side edge of hood
25" from front of hole to edge of relief under hood.
Old Jul 26, 2011 | 09:59 PM
tndrtgr's Avatar
I had my scoop off to paint and here are some pictures of the hood.
67442nut
Sep 16, 2017 01:23 PM
Jul 26, 2015 03:02 PM
Joffroi
Hurst/Olds
Jul 17, 2012 05:44 PM
georgiaboy697
Jul 2, 2010 09:23 PM
