1979 Hurst/Olds
1979 Hurst/Olds
1979 hurst old with the olds 350. this car was sitting in a pull barn for over 25 years.I paid $1950 for this car with out knowing if it ran.needless to say it turned over an ran as well
.my plans for this car is to clean her up an as well as get more hp out of this somged 350 in which i am trying to do so as we speak(top end).I have all ready got some 7a heads for it and having work done to them.Also a new hei distributor with a up graded coil an modulator with adjustable vacum.now i am on the hunt for either an olds 307 a4 intake or an edelbrock.Then for the headers im looking at either headmens or hookers with at least 1 3/4 tube an 2 1/2 out let with a full dual exhaust systems and a hooker aero chamber muffler an I cant for get a new cam,I was thinking a voodoo cam Advertised Duration (Int/Exh): 256/262
Duration @ .050 (Int/Exh): 213/219
Gross Valve Lift (Int/Exh): .485/.499
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1000-5300
Includes: Cam Kit
Includes: Cam Kit
i have read alot of new an past therds an this is what i came up with. an as for the transmission,Does any one know if it has a stock stall converter?
.my plans for this car is to clean her up an as well as get more hp out of this somged 350 in which i am trying to do so as we speak(top end).I have all ready got some 7a heads for it and having work done to them.Also a new hei distributor with a up graded coil an modulator with adjustable vacum.now i am on the hunt for either an olds 307 a4 intake or an edelbrock.Then for the headers im looking at either headmens or hookers with at least 1 3/4 tube an 2 1/2 out let with a full dual exhaust systems and a hooker aero chamber muffler an I cant for get a new cam,I was thinking a voodoo cam Advertised Duration (Int/Exh): 256/262Duration @ .050 (Int/Exh): 213/219
LSA/ICL: 112/108
Includes: Cam Kit
Includes: Cam Kit
halfmoontrail
Nov 20, 2015 08:11 AM
