1974 Hurst Olds
Old Mar 12, 2021 | 11:08 AM
Duke Keicher's Avatar
1974 Hurst Olds
Does anyone know if the Edelbrock (#7551) air gap manifold will fit under the stock hood of my 1974 cutlass 455 W-30 engine, without hitting? Any advice on manifolds would be greatly appreciated. Cam 1500 - 6500 power range. Thanks to everyone.
Last edited by Duke Keicher; Mar 12, 2021 at 12:38 PM. Reason: Update: stock air cleaner
Old Mar 12, 2021 | 12:05 PM
It likely depends upon what air cleaner you have.
Old Mar 13, 2021 | 09:41 AM
VC455's Avatar
Barely Registered
The Air Gap manifold is 2 1/4" taller than your Olds manifold.
Measure the gap between your hood and air cleaner to see if you have that much clearance.
For example, you can use a stack of modeling clay for the measurment.
Old Mar 13, 2021 | 12:01 PM
It has the STOCK air cleaner and that is what I want to use.
Old Mar 13, 2021 | 12:04 PM
Unfortunately I have the motor already at the builder and can not now measure without the motor in the car. Poor planning I guess, but at the time I was unsure what cam and pistons, etc. that I would be using.
Old Mar 14, 2021 | 09:59 AM
VC455's Avatar
Barely Registered
Duke,
Here's a list of heights for some common manifolds:
Olds 406115 W-30 3.30"
Edelbrock 2151 Performer 4.95"
Edelbrock 2760 Torker 5.05"
Edelbrock 7551 RPM Air Gap 5.54"
Prof. Products 620-57027 Crosswind 6.50"
Edelbrock 2810 Victor 8.20"
If someone will measure air cleaner clearance on their '74 Cutlass with 455, you will be able to figure out which manifold will fit with the stock air cleaner.
Gary
Old Mar 15, 2021 | 06:50 AM
I know, that's what I have been looking for. I have posted on many sites with no luck.
Thank you so very much for those dimensations.
Old Mar 15, 2021 | 03:02 PM
VC455's Avatar
Barely Registered
Duke, if you don't get an answer in the next week, bring your thread to the top again with your specific request for measurement. Keep bringing it to the top weekly; someone will respond.
Old Mar 15, 2021 | 04:11 PM
Bill G's Avatar
I have the performer on my 74 Salon 455 w stock cleaner, and it barely fits..but does compress the hood insulation..
not sure if your dual snorkel air cleaner is taller..
Old Mar 16, 2021 | 03:09 PM
Thanks for the advise, as I am new on here.
Old Mar 16, 2021 | 04:58 PM
VC455's Avatar
Barely Registered
Originally Posted by Bill G
I have the performer on my 74 Salon 455 w stock cleaner, and it barely fits..but does compress the hood insulation... not sure if your dual snorkel air cleaner is taller..
Bill, does your air cleaner body measure 2" from the carb mounting surface to the rim around the filter?
And would you measure the thickness of the compressed insulation?
Old Mar 28, 2021 | 10:41 AM
Bill G's Avatar
tried to get a pic,but I'm all thumbs..I measured 2 in from on top of inside lip of air cleaner to rim without lid.
insulation is about 7/8 thick but is compressed about 3/8 at lid..hope this helps..
please note that I know it's an edelbrock performer, but my dad built the engine around 2000, and I'm not the spec guy. It is a 455 from a 75 wagon, hence the offset aircleaner, which I believe Hurst had (hei)
Old Mar 28, 2021 | 02:17 PM
dragline
Feb 28, 2021 12:01 PM
Hurst/Olds 73/74
Hurst/Olds
26
Aug 2, 2013 11:45 PM
ccnclassicoldsmobile
Apr 27, 2013 07:13 PM
jroscar
Jun 28, 2011 11:29 AM
jroscar
Cars Wanted
Jun 15, 2011 02:17 PM
