R-12 valve core source
Old Jun 1, 2015 | 10:23 PM
Anyone know where to get the Schraeder valves for an R-12 system? I have a leak on the low pressure port and I need to replace the valve cores.
I used to sell these things at the auto parts store back in the 80s but I haven't needed any since then and have no idea where to locate them these days.
Old Jun 2, 2015 | 03:58 AM
jensenracing77's Avatar
You can go to most any refrigeration supply store and they will have them. Almost all refrigerants other than 134A use the same service port setup as R12. If your system still has some charge left and you don't want to loose it, you can get a tool that allows you to replace it without loosing any refrigerant.
Old Jun 2, 2015 | 12:53 PM
Thanks for the info.
Old Jun 2, 2015 | 05:11 PM
classicmuscle442's Avatar
Same as a tire valve core.
Old Jun 2, 2015 | 05:19 PM
It will fit but not the same. It will not last like a proper core for refrigerant.
Old Jun 3, 2015 | 07:08 PM
Lady72nRob71's Avatar
Right - the seals are different to withstand the chemicals and pressure.
There is a neighborhood AC shop around here that has them, so any AC shop should.
Old Jun 4, 2015 | 07:28 PM
Been in refrigeration for 28 years, there are the same and have used them many times.
rcktdoc
Jul 14, 2014 12:38 PM
L69
May 19, 2013 11:01 AM
denm3
Jan 9, 2012 01:55 PM
joe_padavano
Brakes/Hydraulic Systems
Jul 1, 2009 10:10 AM
kevdog442
Jan 3, 2009 03:21 PM
