Disc Brake conversion
I have just completed a complete rebuild of the front suspension on my 71 S model Cutlass. I have removed the drum brakes and put on 11" discs, I bought a new brake master cylinder "factory discs type". While test driving today and break-in of the pads, I had decent brake pedal just not what I was expecting, I may need to bleed them again. My question is, do I need to get a proportioning valve or is the factory disc brake master cylinder enough?
The factory combo valve was cast iron and can rust internally:
The aftermarket valves are brass, which avoids the rust problem:
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
