Headlight Removal 1962 Starfire
Old Feb 20, 2014 | 12:37 PM
fabb406's Avatar
Hi,
Just purchased a 1962 Starfire. Low beam headlight is out. I bought both the 61 and 62 service repair manuals and the 61 starfire supplement. The only reference to headlight removal is in the 61 manual. The diagram shows a screw in the top middle of the ring. My car does not have any screws around the ring. Does anyone know how I can remove the headlight?
fabb406
Old Feb 20, 2014 | 06:07 PM
fbonanno's Avatar
I have a 1963 Dynamic 88, and it shouldn't be much different than yours. You can't see any screws head on, but if you run your finger around the rim, you should find a recess where the screw is located. Inner and outer head lamp screw are in a different location. Approximatley 6 oclock and 4 oclock. Hope this helps you, and let us know how you make out. Regards, Frank.
Old Feb 20, 2014 | 06:12 PM
fabb406's Avatar
Thanks. Will give that a try and let you know
6inarow
Aug 27, 2019 11:22 AM
oldrelics
Aug 4, 2014 08:41 PM
BeenThere
Apr 2, 2013 03:21 PM
71supreme
Sep 22, 2010 05:28 PM
jaunty75
Jul 31, 2009 04:19 PM
