1982 Regency Brougham Fuel Pump
Old Dec 8, 2013 | 09:03 PM
Machwest's Avatar
Has anyone had issues with fuel pump on 98, my electric pump has stopped working and I believe it is located on top of fuel tank. Does it have a separate fuse? Can you get to it through the trunk or do you have to drop tank? Cheers guys
Old Dec 9, 2013 | 01:06 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Regular old gasoline cars have a mechanical fuel pump bolted onto the passenger side of the engine block.
http://www.proheader.com/image/pf117c.gif
Old Dec 9, 2013 | 04:01 AM
You should be able to buy one at any auto parts store.
Old Dec 9, 2013 | 05:30 AM
fdwheelman's Avatar
Unless it's fuel injected, it should have a mechanical fuel pump which would be on the front of the block. They are like 30 bucks. One of the easiest jobs you'll do.
Old Dec 9, 2013 | 06:51 AM
Originally Posted by fdwheelman
Unless it's fuel injected...
The only engines offered in the 1982 Ninety Eights were the 350 diesel and the 307 gas engines. The latter used the CCC Qjet and a mechanical pump.
Old Dec 11, 2013 | 08:55 PM
Did the 350 diesel use the same mechanical fuel pump to move diesel fuel to the injector pump?
Sorry to hi-jack the thread.
Machwest
Aug 14, 2014 05:32 AM
Machwest
Jan 21, 2014 07:01 PM
Varmit
Ninety-Eight
Oct 2, 2012 07:09 AM
bigblue82
Feb 25, 2012 02:38 PM
Monique6ft
Feb 7, 2009 04:48 PM
