FYI ARP head bolt torque specification different
Old Jun 12, 2013 | 11:06 AM
joepenoso's Avatar
Thumbs up FYI ARP head bolt torque specification different
FYI
Factory shop manual says to torque head bolts to 85 ft. lbs.
ARP bolt co. says to torque them to 70 ft. lbs.
Phoned ARP and they said to follow Olds tightening sequence but torque to 70.
joepenoso
joepenoso
Old Jun 12, 2013 | 04:21 PM
BlackGold's Avatar
You should always follow the instructions of the manufacturer of the fasteners. The proper torque depends on the design and material of the fastener and on the lube you use (again, follow their instructions for lube).
Old Jun 12, 2013 | 06:25 PM
Originally Posted by BlackGold
... follow their instructions for lube
Yes, ARP torques are for ARP lube ONLY.
Old Jun 12, 2013 | 06:49 PM
TripDeuces's Avatar
Required torque specs actually go up on ARP bolts and studs if you use anything but their lube. EI: oil, moly, etc.
Old Jun 14, 2013 | 05:30 AM
joepenoso's Avatar
I used 70 ft. lbs. and their lube that came with the bolts.
joepenoso
Old Jun 16, 2013 | 07:12 AM
joepenoso's Avatar
On the other hand maybe I will up the torque................................
http://realoldspower.prophpbb.com/topic812.html
especially read the last 3 postings
joepenoso
RAMBOW
May 27, 2017 06:11 AM
EightballZ
Mar 24, 2014 05:03 PM
ohiocutlassparts
Jan 15, 2014 04:36 PM
Al2011
Apr 18, 2013 10:49 AM
MDchanic
Mar 25, 2012 06:30 AM
