'57 olds dash
'57 olds dash
Hello all. I'm trying to remove the Instrument panel from a '57 olds. I have removed all of the other chrome, taken the gas gauge out, the shift selector needle out, dropped the steering column down, and removed every screw or nut in sight. There is something still holding it firm to the dash. I have followed the manual (which isn't greatly clear) but cannot see where it is still attached. Unless it's in the area above the speedo housing. Actually I can't even get the speedo housing off. Help!! Thanks in advance. Charly9g. or wfg4u@aol.com
Big Mikey
May 12, 2013 05:40 AM
