Upper and lower radiator hose springs
Old Dec 27, 2012 | 03:30 AM
jjokrm's Avatar
Anybody know where I can find the springs for the upper and lower radiator hoses or where I can find the hoses with them already installed? This is for a 68' Rocket 350 cutlass. Thanks.
Old Dec 27, 2012 | 04:07 AM
The upper hose doesn't have a spring - only the lower one.
I've never tried to buy one.
Old Dec 27, 2012 | 04:14 AM
66luvr's Avatar
I'm told by friends in the parts business, the springs are no longer used. The new hoses are made heavy so they do not collapse so no springs necessary.
Old Dec 27, 2012 | 05:13 AM
jjokrm's Avatar
@ Eric, my upper radiator hose did have a spring in it (maybe wasn't supposed to). Anyway the springs in both the upper and lower radiator hoses were all rusty and in numerous pieces. I'm not sure how old the parts on the engine are in relation to the actual year of the car (68') as it's not the original motor, but it is an Olds Rocket 350, which is what was factory. I appreciate the quick replies guys. I'll just install my new Goodyear radiator hoses and clamps without any springs. Thanks again!
Old Dec 27, 2012 | 06:09 AM
Well, for whatever it's worth, the water pump pulls the water from the radiator into the pump, which can collapse the lower hose, bit the upper hose, which carries hot water from the engine to the radiator, is generally under pressure and will not collapse.
Old Dec 27, 2012 | 06:37 AM
jjokrm's Avatar
Thanks Eric. I appreciate it.
Old Dec 27, 2012 | 08:16 AM
75cutty455's Avatar
I know when I rev my 455 at the carb, my bottom hose collapses. I purchased that hose from Autozone not too loong ago. Maybe I'll try N n n n Nappa know how. next. he he he
Old Dec 27, 2012 | 08:30 AM
brown7373's Avatar
Most NAPA hoses don't have springs either, for the reason stated earlier. They are made so they won't collapse. I haven't had any issues when using a NAPA hose.
bluefire
Feb 25, 2013 01:51 PM
herdez55
May 22, 2012 04:49 PM
w-30dreamin
Mar 29, 2010 06:32 PM
Dan Wirth
Oct 8, 2009 11:56 AM
jensenracing77
Jul 22, 2009 04:55 PM
