Fuel gauge/tank sending unit
Old Dec 11, 2011 | 09:46 PM
KDW's Avatar
KDW
Hello Form
I have a 72 olds cutlass that I’m having a problem with again lol.
Ok here I go, first the fuel gauge was pegged past full did the entire test including grounding the sending unit wire and gauge would read empty etc.
So I replace the sending unit with a new on and put 10 gallons of gas in tank, gauge was reading about half, which looked normal so I figured I’m good to go.
Over the last 2 or 3 weeks I’ve been working on the car in the garage tuning, fixing A/C etc and just last night the car would start and could not figure out why since the gauge was reading ¼ off tank fuel. I had another gauge, so I swapped gauge thinking maybe the old gauge was inaccurate, same reading ¼ of tank.
Also looked at see thought gas filter under hood and just what I suspected it’s not full and no full in tank.
What could cause a new sending unit to give gauge the wrong reading?
Its grounded new ground to body etc.
Any help would greatly appreciated, thanks in advanced.
Kevin
Old Dec 12, 2011 | 06:30 AM
Run to Rund's Avatar
If the gauge is good, and the same as for a 1966, it will read full if you take the "hot" wire off the sending unit and leave it dangling. If you ground the wire, it will read empty. Your problem sounds like a bad sender in the tank, or the float is rubbing on something and not traveling freely.
Old Dec 12, 2011 | 08:57 AM
KDW's Avatar
KDW
Thanks for your help
I grounded the wire at the trunk that connect the sending unit, the gauge did read empty.
I never thought about disconnecting the ground. If I disconnect the ground and it still reads 1/4 could this just be a bad ground or do you think it could be the sending unit? I did buy this thing from auto zone lol.
The ground on the tank now is a shelf tapping sheet metal screw going straight to the body over axle, is there a better place to ground?
dallasite21
Oct 1, 2021 05:21 PM
70 ctls
Mar 17, 2015 09:18 AM
pfergy600
Oct 4, 2014 05:29 PM
1carsick
Oct 17, 2012 09:10 AM
