Will these headers fit?????
Old Feb 16, 2011 | 05:13 PM
Dave Siltman's Avatar
Hi Guys, I bought a used set of Flowtech coated headers that were supposedly for a Cutlass. I can't find any part numbers but I do know that they were installed in a '81 Trans Am with a 455 Olds motor. I'm planning to install them in a '72 Cutlass S with a 350, auto. on column, A/C, and changing from power drum to power disc with one of the new "complete" power disc brake change-over kits. The catalogs show the headers listed as fitting the Cutlass 350 and Trans Am with a 403. Any thoughts, ideas, or suggestions? Thanks in advance, Dave.
Old Feb 16, 2011 | 05:59 PM
Rickman48's Avatar
As the catalog lists your application, you should be fine!
Be aware - you may have to make moderate adjustments to your appication.
delta254
Sep 20, 2012 10:05 AM
michaelallen747
Wheels and Tires
Jan 20, 2010 09:49 AM
jensenracing77
Aug 14, 2009 02:46 PM
BobM
Dec 31, 2007 06:15 AM
77supreme
Mar 12, 2007 03:42 PM
