64 radiator brackets
We had an aluminum radiator custom made from a place called Alumi-tech in Michigan. It's going in a 64 Cutlass that currently has the stock core support in it. The problem is that the new radiator will not fit in the stock brackets - lower or upper. We also need to fit the stock fan shroud back on the radiator. The new radiator is 2 3/4" wide. It seems that it may fit into stock brackets if they were for a 4-core. Was there a 4-core option in 64? If so, would this work? If not, what would? Or will we have to fab up new brackets?
Thanks for the help.
olddaz
Aug 27, 2014 06:39 PM
1k442
Jun 6, 2013 10:59 AM
1965cutlassragtop
Apr 3, 2011 03:46 PM
