New aluminum radiator and fab'd brackets...sweet!!!
Old Apr 2, 2011 | 08:14 PM
1965cutlassragtop's Avatar
So I just fab'd up some upper and lower radiator support brackets to accomodate this new 3row aluminum radiator to cool things down a bit, and freshen up under the hood. Looks good!!!! Just gotta throw in the alternator, fan, belts, and fill her with fluid....then turn the key, hopefully!!!
Old Apr 2, 2011 | 09:19 PM
Aceshigh's Avatar
Looks good!!!!
I'm sure that new aluminum radiator will drop it down a bit in temps.
That engine bay looks like it has so much space in it around that motor.
You could practically lay in there. Not like the new cars.
Old Apr 3, 2011 | 03:46 PM
So I got it all together, and she started up no problem, so that was good news....seemed to run about 5-10 degrees cooler than before which is what I wanted. Now I have to remedy the pain in the *** kickdown cable leak on my th350. I've discovered this is a common problem with these kickdown cables, trying to decide to get a new cable or just eliminate it all together.
brownbomber77
Mar 23, 2022 02:29 PM
olddaz
Aug 27, 2014 06:39 PM
therobski
Body work
Sep 29, 2010 06:43 PM
csstrux
Mar 2, 2009 08:32 PM
J-(Chicago)
Jan 18, 2008 03:46 PM
