Dissassembling air cleaner
Old Oct 22, 2010 | 08:20 AM
oldzy's Avatar
On my 72 Supreme 350 4bbl, how do I remove the green plastic AC thing on the inside, and the side plastic vent tube thingy on the inside/outside? I am getting all my parts bead or soda blasted. Thx.
Old Oct 22, 2010 | 08:43 AM
InfoJunkie's Avatar
InfoJunkie
If this is the green thing it's fastened from the outside with some clips.
The other thing should be held in with a horseshoe clip on the inside.
Old Oct 23, 2010 | 08:11 AM
oldzy's Avatar
I managed to pry it out. The two vacuum nipples seemed pressed into the clip on the bottom. Where to get a replacement? It is some kind of sensor?
The original vent tube though I had to rip out as it was hard like a rock. I see Fusick sells replacements though.
Old Oct 23, 2010 | 03:44 PM
InfoJunkie's Avatar
InfoJunkie
It is an air cleaner temperature sensor. It was held in by push nuts. New sensors are still available and they come with pushnuts(see pic in my prevoius post)
69CutlassAlex
Dec 2, 2011 08:01 AM
WTony
Jul 3, 2010 11:12 AM
dan1s
Apr 17, 2010 08:14 AM
StickW31
Feb 25, 2010 01:14 PM
Viper
Aug 13, 2008 10:58 AM
