394 - 371 Olds Oil Pan Question
I am looking for an Olds oil pan with the extra capacity canister on the side. I understand that they were used on the 371 & 394 Olds. Does anyone know if this pan will fit the 303? Anyone got one for sale? If it will not fit, I would still buy one and cut the side out and weld it in my 303.
look for the '61 or 62 and up 394's - they have them.. Im not too sure they are an 'extra capacity' pan - I still calls for 5 quarts with a oil filter change. If you trying to adapt one on a 303 be aware that the huge oil filter canister on the 303 my be hitting the extra resevoir on the pan
As I have a 62,this thread caught my eye.
I have to agree with an earlier post: Since a complete oil/filter change calls for 5 qts. of oil, where is the extra capacity? Additionally the location of the contraption is up so high on the pan, I fail to see how it would hold any oil that could be used?
I have never had the pan off, but it seems more logical the, whatever it is, houses some part, like part of the oil pump or something.
What I do know is, it is a royal PITA to change an oil filter because of the obstruction!
IIRC, the added "can" doesn't house any parts. Today, I'd mock up a cardboard sump that clears everything and allows removal of the engine (enough clearance to crossmembers, etc.), then weld on a sheet metal sump and make a deeper oil pump pickup if needed. I don't know that the extra capacity matters anyway, on a stock engine.
If you want extra capacity without dealing with an obstruction you could run a remote oil filter kit with a large oil filter intended for diesel engines. I've seen this done numerous times. Here is a remote oil filter kit for your application:
http://www.summitracing.com/parts/TRD-1120/
The extra capacity canister is mounted very low in the side of the pan, it houses nothing. I don't want to run a remote filter, I want this because it is an OLDS part. Am building a rod and want to use Olds parts on it. Any one got one for sale????
